  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
cam - you seriously need to do your homework on fuel regs and pumps.
Increasing the pump strength will assist in delivery of fuel pressure - but the effectiveness of this is severely limited by the stock injectors - and you need management to run other injectors.
besides this, you're probably not managing enough boost to justify an upgaded pump.
I dont know about other brands, but I know malpassi's let you squeeze more flow out of both the standard fuel pump AND out of the duty cycle of the standard injectors - and aftermarket regulators can provide a "backup" in-series regulator for the stock one (although the stock ones are pretty good anyway).
but until we start playing with post-fmic engines, both have limited use.....but might be worth grabbing if really cheap.
always had top of range oil in there so i cant say that over Mobil 1 that was in there before theres any difference..... there mightve been and im just a dumbass female that didnt feel it. *shrugs*
i dont know how many litres sorry .... my mech did it.
ah transmission oil hmmmmm ...... dont think mine is Redline .... i dun know ...... *runs to check service invoice* hahaha really should pay more attention when Slako talks about what he's done to my car!
Hey Erin - u always come on around my hometime - the indian pacific goes to perth but leaves from sydney. :D Left u an email for u in morning.
I have to go home now
*hugs*
Lauren
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
