Originally posted by Micko
Ken - how did you go in the rally, & how did the new engine perform:D
Rob - turbos will probably not be on for at least the next 2 weeks:(
Got 3rd o/r but was only there for the fun and ****ed around too much.
Like the Classic Rally only a lot better organised and Waaaaaaay cheaper.
Great closed road sprints around collie, grimwade and Harvey and some laps of the powerhouse circuit mixed in with auto and motorkanas.
Was a TOP w/end:D
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Engine feels plenty strong. Is running way too rich ( back of the car is black and the vids show heaps of smoke out the arse)
Autronics is away getting updated and will be back in a week or two.
Was down to .9 bar boost on 2 nd day from 1.1 and only found the split intake pipe tonight.
In that spec , still hosed Darrl sosa's evo 7 in a side by side drag 3 times. hehehehe
Cheers
Ken
Ken - was the car running overly rich because of the split pipe or is that what to expect with more boost on the std ecu?
No , was running rich before the split pipe so would expect you to have to retune.
They are fat on the fuel std and very fat at the top which is where those 2530's will pull the air up to on the map.
Red calipers????
now THAT is rice:D :rolleyes:
Cheers
Ken
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity. Edit: 11kg each (or 10.9/11.1 depending on what my scale decides over multiple tests, the 18x11 don't seem to weigh noticeably any more than 10.5)
