  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
ahhh so short back n sides in the proper milatary style eh? ..... why dont u go a mullet :) cmon u know u've always wanted one ...
Not much Snyper not much at all ..... just wishing the day away haha ..... still havent checked those lotto tickets could be a millionaire and be here for no reason!
back - IT was checking everyones computer thought they were going to do mine .... but didnt :D
they are probably the coolest blokes in the building ..... they are going to burn my drift clips onto CD's so i can take them with me when i go :)
