  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Ohhhh Don't tell me its cold in Perth.... I am comming home tomorrow...... I want some nice sunny weather to welcome me home :O
Cricket is going pretty good..... Our wednesday night cricket team is on top of the ladder and the Sunday Superleague team is right up the top as well ( I think we are second ) so all is going pretty well actually.... although we are playing Ballajura this weekend.... 1st plays 2nd ... going to be a tough game :D
