  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
There were soooo many sunday drivers on the road today!! it was like phuckheads day out or something! maybe its cos im tired and my patience is lower than normal but one person was doing 60 in an 80 zone!! GRRRRR
Originally posted by dan_the_man
Who got the highest hp today?
Gawd knows cos the 4wd were done at XSpeed and the 2 wheel drives at Genie.
I know Ant ran about 430 at the treads out of his Datto 1600.
Cheers
Ken
Sorry , I did move over...;)
Cheers
Ken
Sides I was trying to get to that Maloo ute but couldn't get the lights right.
( note that gtrken does not condone excessive speed or dragging on public streets )
yea , phucken right:D :uh-huh:
Cheers
Ken
3/4 points ..... not sure ..... think its 4. ;)
nearly got done on the way to the breaky cruise ...... hurtling down abernethy rd 110km ...... motorbike policeman driving along other side ..... u shouldve seen his head turn as this black clur went past ..... *insert a lot of swearing from me* jam on brakes - see him jam on his in my rear vision mirror so i prepare for the worst and get behind slowarse car in lefthand lane ...... but despite me thinking he turned around he didnt - lucky me :)
Originally posted by AeroGrace
anybody see a R32 GT-R in custom purple? Driven by a chick....
did it go on the dyno?
Skyes and its for sale and is near std mechanically so doubt would have run.
Cheers
Ken
yeah saw the ute .... but he was either stuck behind someone or was just grandpa driving ........ i know 2 particular holden clubbie that call my car "jap crap" I would love for u to show whos boss too ;)
Hmmm , then you would have to resort to what we were discussing
1 Low cut top
2 High cut skirt
3 Crying
or 4 is the job that you mentioned:D :)
Cheers
Ken
Or like drews mate who whispered in Liz's ear that I should get a Commodore.hehe
Russ's comment re. why buy something slower was good:)
Cheers
Ken
haha i have done all three in front of a cop and it works ..... never had to resort to 4th ;) just play the dumb blonde (comes naturally to me) and they just think your late for something and u normally drive like a grannie. I love it when cops try and find excuses for me tho - that was sooo funny "oh you dont know the speed limit around here do you (despite it only being 2 blocks from my house) and your late for work ..... where do u work ..... oh that sounds cushy"
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
