so do i... i was hoping to take a friday off this week and piss off down south to hide and get my head together.. guess that won't be happening for a while now with time off and extra $$ to spend... and no transport.. :)
poor me... hehehehe... **** i should just got shoot myself and get it over with.. LOL.. :(
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
haha can we share the gun Cam :( ..... more economical that way. Yeah not a bad idea actually just take Friday off and go down to my folks place in Bunbury. They are going to Melbourne soon thank god!
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
