  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Paul i dont think your the best person to judge it cos your suspension is so hard - that its normal to you ...... need someone with more stock like mine i think - i just know what the car is like and i appreciate that its been lowered and stuff .... but it was nowhere near like that before - i can even pinpoint the day where it changed to the way it is now.
nah tried that - on my old tyres anyway.
I would take it to a suspension shop and ask them what they think but a girl going into a shop and saying theres something wrong with her car but doesnt know what it is tends to put dollar signs in their eyes!
paul the surface u had it on didnt give me a chance to priove my point that stretch of roe hwy is a newly surfaced flat road ..... u try taking it to one of country runs ;) its no fun cos the car is bouncing like crazy vibrating .... not to mention the state of my brakes at the mo. I cant push it cos its just not safe.
my friends that i shared house with (Jodi and Rachael) would drop their cars to this mechanic they thought was ripping them off. so id pretend to be hubby and pick the car up. there was always a 'problem with the computer' when i asked for the bill. i think they were making a blokes version of teh bill!
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
