  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
look at this shit! it gold :)
Originally posted by Boostzor
U guys realise that there is nothing to gain by whoring right? no1 looks at ure post count and thinks "wow eh must really know his shit if he posted that much" :lol: look at box head for god sake he wouldnt know a turbo from a washing machine yet look at his count.
day - just unresolved isses everywhere. I can see a good 90% of them heading south tho.
ins - russ, you are a youngin. It all depends on age and history - and if you got no age, you got no history.
I got some quotes for $6000.00. I told them what Ithought of that Idea. And that was from a company that many people on here reckon is awse!?
