  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
i didnt end up doing yoga last night cos it didnt give me enough time to do my cardio and weights properly and they are more important :rofl: pushed myself a little harder cos its stopped hurting but im not sore so maybe i am being a wimp ....
Alex i've been there but forgot what street it is on in Mt Lawley - will look it up for you :)
Found out what day this chick is coming back thru sneaky means of bosses email as previously mentioned ..... 5th August. Which means thats probably D-day for me ..... geez nice of everyone to let me know!! :/
hypothetically ....... if u wanted to respray your car in a metallic paint (nothing hoity toity like chamelon tho) .... full respray .... how much would this certain person be looking at :/
not bad i was thinking more 8K ...... but with a big shiny intercooler take the pice to about 6K eh?
mmmmm :drooling: me thinks i may work towards that - it'll be a pretty special machine once ive finished with it .... cos in reality i dont want any other car apart from a GTR but they cost to much to maintain .... so i might as well throw money away into this one for now :/
if i were u id spray my gtst like EVIL33 or just respray it super glossy black like them new cars
or if u wanna be more adventurous, maybe Lemans Blue or Ferarri red?
yea i love my gtst hehe,if i resprayed it itll probably be super glossy black, yea don think ill get a GTR till ages, its expensive to modify and mantain
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
