  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
it would be cool - but no way would he give it up ..... he's done nothing but play with his new toy for a week straight now!! its like u whoring .... he just wont get off the bloody computer/phone thingy!!
u can drug me :P no complaints here haha
Alex without shoes on your actually a bit taller than me cos with heels on i "just" come up almost to your height...... and dun call me lanky i hate it - used to get called that in school - and u dont want two angry females not talking to u now do u ......
