haha aidwin .... well dont think ive ever seen that side of you .... thought you were always > :innocent: .... paul has obviously been a boad influence :P
awww backseat .... well im not sacrficing all my space for beer again peoples .... so its either me in front seat and u take beer or me in backseat and no beer *jk* :P im serious - DOES ANYONE HAVE A GAMEBOY!!
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
Alex without shoes on your actually a bit taller than me cos with heels on i "just" come up almost to your height...... and dun call me lanky i hate it - used to get called that in school - and u dont want two angry females not talking to u now do u ......
I dont want one angry female!
edited to protect the innocent.
well if i knew what you could do i would tell ya but i dont know either ...... whats done is done i guess.
Her and i are probably going for a run this weekend ..... taking Mel as well .... haha Hyundai girl ..... *one of these things does not belong, one of these things is not lie the others* ..... :P
