  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by G0DF4Th3R
yeah well soon i wont own the car in question too
will i be banned? :D
nah man.. didn't mean it like that..
just an observation that one of the people who run this forum doesn't own one, thats all.. :)
