  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
it was pay day today $$$ *cha-ching* saving up for a rainy day .... actually if i really budget this week then with next weeks pay - i should be ok without a job for a couple of weeks .... cos its actually WITH a job i spend the money .... parking, lunches, fuel .... i should also be able to spare the money to have my brakes done - decided to do it when i ge the arse that way i dont have to worry about co-ordinating getting the car there then getting to work etc etc etc ....
i guess its not like im going to be battling - its just i prefer to have more than i need instead of less than i need..... i mean it only cost me $500 for 2 weeks partying it up and not scrimping on anything for those 2 weeks .... so im sure i can comfortably live off $1.2K for a few weeks in boring ol perth.
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
