  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
it was pay day today $$$ *cha-ching* saving up for a rainy day .... actually if i really budget this week then with next weeks pay - i should be ok without a job for a couple of weeks .... cos its actually WITH a job i spend the money .... parking, lunches, fuel .... i should also be able to spare the money to have my brakes done - decided to do it when i ge the arse that way i dont have to worry about co-ordinating getting the car there then getting to work etc etc etc ....
i guess its not like im going to be battling - its just i prefer to have more than i need instead of less than i need..... i mean it only cost me $500 for 2 weeks partying it up and not scrimping on anything for those 2 weeks .... so im sure i can comfortably live off $1.2K for a few weeks in boring ol perth.
