haha yeah i live at the bottom of kalamunda hill - all the chics in kalamunda are hippies - its like a mini Nimbin .... my parents wont move tho ;) ... they have even arranged to build upstairs of our house ..... time to move out soon me thinks!
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
