haha not the artist eh Bam :) all you need is a scribble on a page to represent a crashed car anyway. Nah i used to fill out works car insurance forms - i got pretty good at crash diagrams ..... dont think they appreciated the artistic talent of flames tho!
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
