  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
well Alex im trying to talk him into around york way so we can do roads like that - you know even if we do a few roads like that and come back and have lunch in john forrest national park!
i am phucking making suggestions ...... not my fault men never listen :(
Or we could do the back of Serpentine then have lunch at Araluen Botanic Gardens ..... and u can have your BBQ and your phucking tulips!!
