  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
nah couldnt get a restraining order .... theres good and bad with everyone .... its jus ttha the had both and two different opposite extremes i really do think he's got psychology issues that a proffessional needs to sort out ...... his brother is the same and his brother is almost the same age as you ken ... actually would be around the sam age as you!
What , 21 ??
Cheers
Ken
haha no Alex is about 50 ..... his so Alexander is about 15 ..... oh and Alex and Andys dad is also named Alex ..... phucking Scottish!!
Sheesh
pick on Ken:D
I am nowhere near 50 young lady. hurrumph..
46 is nowhere near 50...
Cheers
Ken
its a Lexus bam
cant find that website .... addy is at work.
I wish !!
Actually it's a POS mazda ex courier van I cart crap round in.
Anyone want to buy it ??
puhleeeeeze:D
Cheers
Ken
Originally posted by G0DF4Th3R
man Ken's got a lot of cars
Huh , you can talk.
You got more houses in asia than I got cars:D
And chauffers, and bodyguards ( not that my body is worth guarding anyway ):P
Hehe
Cheers
Ken
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
