  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
didnt say i was going to dye it - going to keep it blonde ..... and it wont be going too short cos i hate short hair - just got chop some of these dead ends off and make it healthy again.
Yeah as much as I would love to have the flashiest, fastest , most powerfull car here, I know that I should be putting some money away for a house too.... Thats why I have only done the small mods....
Changing the turbo is a big/expensive mod though... change the turbo then you probably need to change the fuel pump, emgine management, fuel injectors,wastegate,dump pipe and anything else I cant think of!!!!
Tell me what you think the next stage of mod would be for my car though.... the only thing I can thionk of really is a lightened flywheel...
Bah even with almost 300HP I still cant crack a 13 sec pass at the plex.... granted I have only ever been once though :)
Yeah but having 3 or 4 PS2's hooked up and racing your friends should keep us entertained for a while :D
I will look at the cruise next Sunday but I play Superleague crikcet sunday afternoons so I may not be able to make it because I believe the cruise is going into the hills???
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
    • If there's oil in with the clutch, I hope it finds its way out even if that hole has a cover/grommet 😛 I don't want oil near my cars clutch! 😛 Interested to hear the answer about covering it, I'm assuming a bung for a gearbox from another car that has a grommet to suit.
