  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Guest Nobel Soul
well nizy i reckons it wont be nice if it happen that the only place he finds you is on the rear view mirror, i dont care what it is, but i sure dont like being in his rear view mirror. I did some research after i heard this, and their are alot of independent guys out their that say, the xr6t has been under powered before release, while when ford tested it, they did out puts of upto 800kw. Now that is heaps for a ford
that would be a very exceptional XR6T.
Like VERY exceptional. I think he is probably yanking your chain.
the xr6t is not a particularly easy car to make really fast - because it has such a large displacement. to produce that sort of time, you're looking at 800+ ps, which would require a big turbo and some serious internal work.
the catch is, that because he throw is so long for each cylinder, he'd struggle to find rods that would put up with the sort of hammering that a high outpurt turbo would put an engine under at very high boost.
so, I call b/s on the 10 second XR6T.
Nobel what i dont understand is if your flying the flag for Ford so high .... then get dad to buy you one :P ..... we are really trying to care .... but as this is a Nissans forum we really dont give a phuck.
i know my car aint the fastest on the planet .... but it still kicks enough male butt that im more than happy :) not too mention its a Nissan!
i just dont get some people! What does he want us to do .... "a friend of a friend who knows some guy at the other side of the country may have a 10sec XR6T" ...... so? want us to worship the ground you walk on ..... or sell all our cars for Fords now :P ... you are trying to achieve what??
Guest Nobel Soul
zanda, well i did take it all with a pinch of salt, so i did my research and here is what i found...
240kW at 5250rpm and 450Nm from 2000-4500rpm
6psi turbo pressure
that is what its set to as the standard, and the compression ratio is 8.7:1. Being a 4 L engine it has alot more potential. I just wonder what ford got out of it before it reached danger zone.
capa http://www.capa.com.au/xr6.htm has already released kits that boost it to 350kw and they are working on a 380kw which they think they can achieve no sweat.
I also heard from a ford guy that the trubo can be set as high as 32psi, but i still got to verify that.
There is alot of work happening on it, heaps of people in the east are trying things out on it.
I am just waiting to see if those numbers are true.
Guest Nobel Soul
I was just sharing some news i heard, after all this is a car forum, and the filter doesnt seem to be set to pick out holden and ford and Maybe you have missed it all this time.
NO I DONT SUPPORT FORD, to me they just stupidly designed, the fools add weight then they think, oh shit its laggin so more fuel ahh thats better.
I hope that settles your misery nizmo, i suggest you look into something more entertaining if this bores you so much.
Gad daaaaaaaiyum some people
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
