  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Guest Nobel Soul
well nizy i reckons it wont be nice if it happen that the only place he finds you is on the rear view mirror, i dont care what it is, but i sure dont like being in his rear view mirror. I did some research after i heard this, and their are alot of independent guys out their that say, the xr6t has been under powered before release, while when ford tested it, they did out puts of upto 800kw. Now that is heaps for a ford
that would be a very exceptional XR6T.
Like VERY exceptional. I think he is probably yanking your chain.
the xr6t is not a particularly easy car to make really fast - because it has such a large displacement. to produce that sort of time, you're looking at 800+ ps, which would require a big turbo and some serious internal work.
the catch is, that because he throw is so long for each cylinder, he'd struggle to find rods that would put up with the sort of hammering that a high outpurt turbo would put an engine under at very high boost.
so, I call b/s on the 10 second XR6T.
Nobel what i dont understand is if your flying the flag for Ford so high .... then get dad to buy you one :P ..... we are really trying to care .... but as this is a Nissans forum we really dont give a phuck.
i know my car aint the fastest on the planet .... but it still kicks enough male butt that im more than happy :) not too mention its a Nissan!
i just dont get some people! What does he want us to do .... "a friend of a friend who knows some guy at the other side of the country may have a 10sec XR6T" ...... so? want us to worship the ground you walk on ..... or sell all our cars for Fords now :P ... you are trying to achieve what??
Guest Nobel Soul
zanda, well i did take it all with a pinch of salt, so i did my research and here is what i found...
240kW at 5250rpm and 450Nm from 2000-4500rpm
6psi turbo pressure
that is what its set to as the standard, and the compression ratio is 8.7:1. Being a 4 L engine it has alot more potential. I just wonder what ford got out of it before it reached danger zone.
capa http://www.capa.com.au/xr6.htm has already released kits that boost it to 350kw and they are working on a 380kw which they think they can achieve no sweat.
I also heard from a ford guy that the trubo can be set as high as 32psi, but i still got to verify that.
There is alot of work happening on it, heaps of people in the east are trying things out on it.
I am just waiting to see if those numbers are true.
Guest Nobel Soul
I was just sharing some news i heard, after all this is a car forum, and the filter doesnt seem to be set to pick out holden and ford and Maybe you have missed it all this time.
NO I DONT SUPPORT FORD, to me they just stupidly designed, the fools add weight then they think, oh shit its laggin so more fuel ahh thats better.
I hope that settles your misery nizmo, i suggest you look into something more entertaining if this bores you so much.
Gad daaaaaaaiyum some people
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
