  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nobel Soul
zanda, well i did take it all with a pinch of salt, so i did my research and here is what i found...
240kW at 5250rpm and 450Nm from 2000-4500rpm
6psi turbo pressure
so, its got a small turbo, producing reasonable power - but a long throw and a poor RPM ceiling as a result. But, to it's credit it makes full boost at low revs because of it's high engine capacity.
that is what its set to as the standard, and the compression ratio is 8.7:1.  Being a 4 L engine it has alot more potential. I just wonder what ford got out of it before it reached danger zone.
I disagree with this statement - and not because it's a ford, although I do think that's why it's happenned.
When commodore moved to a turbocharged engine for the VL - they did so through a negotiative bargaining agreement with nissan - because Nissan were familiar with the engineering behind turbocharged engines.
they made a n/a 6, a turbocharged smallish six, and a V8 holden for the clan who are committed to their big block pushrods.
however, ford recognised that in order to sell cars to the modern australian market, any performance vehicle larger than a 200sx has to have big cubes. this is both what will make the car a sales success and a performance failure.
big stroke = big buckling forces = bent rods.
capa  http://www.capa.com.au/xr6.htm has already released kits that boost it to 350kw and they are working on a 380kw which they think they can achieve no sweat. [/b]
so it doesnt make much more power than a semi-stock GTR? which will do high 12s?
I just dont think people realise how much faster a car has to be to do tens.....so they make up some horseshit about 10 seconds.... I can't see it happening.
I also heard from a ford guy that the trubo can be set as high as 32psi, but i still got to verify that.
[/b]
I beleive that the ford turbo is a ceramic wheel - so I doubt it.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
