  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
no probs Rob ...... how you enjoying the new turbo buddie :D
Cam - nah im too nice to do that .... besides the way my life is going at the moment i think he's proven a point ..... even tho i hat eto admit it .... no one will love me like he does. But no didnt ansewer my phone on saturday anyway to find out what he wanted ..... again.
This week is my last week ..... yipppeeeeeee!! so happy but i did spend $250 on a Gameboy advance today ....... need an income to fund these things :) But it'll keep me amused on the way to SA
bam - i read you saying it somewhere... :D got pics.. but not here at the moment.. will post some when i get em...
lauren - you're not even in your mid 20s.. don't think that you can't find someone worthwhile.. thats just crazy...
As you may or may not have figured out the posting rules have been changed to 1 every 3 minutes.
This mainly due to a recent increase is useless and utter crap in some forums mainly the state whorethreads. The admin are decidin wheather to keep them or not. For those who want to complain, theres already an off-topic whoring section all to itself, also there is a Perth irc channel as well as a Victorian one.
So either prepare for this thread to dissappear and keep the other threads on topic or keep this thread going the way it has of late general day to day converation between a bunch of mates.
I have no problems with the direction of this thread, just be aware of the above and don't reduce it to the crap that has been happening elsewhere and it should be here to stay.
troy - understood.. why keep the history of this thread anyhows? why don't they delete it if they're having storage issues? fair enough opinions on the crap posting though...
bam - u whore.. :D should've seen some of the widebody m3 convertibles i found on the m1 out of london.. wiked cars.. would trade mine in a second... :)
lauren - look aorund.. there's quite a few people you could lean on i think you'll find...
Agreed on it taking out the "friendliness" factor.. i feel i've come to get to know quite a few of the people via this thread..
hi joel...
its not a storage issues its a content issue
with the vic and nsw clubs up and running and possible sponsors now reading the forums with more interest, some of the crap that goes on just isn't good for them as a club.
as i said earlier i see we have no problem with our whore thread as long as it stays the way it has been for the last few months.
we still need to work on some of the other threads in the WA section but thats no big issue as the off topic posts have been kept mainly to a minimum within the posts related to the relevant topic.
Cam I think i just want to get comfy now ..... sick of mind games, sick of a lot of things ..... just want something stable ..... something to come home too :D
My friends just seem to meddle. im growing tired of it .... no wonder andy always used to tell my mates to phuck off .... cos at the moment im feeling the same ...... mels mates have compeltely taken over my end of work celebrations ..... oh we are doing this and that ..... they havent even asked me what i want to do .... it shits me sooo much!!!
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
