yes Matt :P im going to make an effort to be there - going out sat night but they forgot to pay me this week so its not like i got enough money to have a hangover the next morning anyway ..... so short ansewer: At this stage yes i am :D
HEY! I jus tread the funniest thing!! This chick exactly the same height is me (188cm) is marry mini-me off austin powers - theres a photo of them together!! haha it would be like marrying a baby!! yuk
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
they were engaged but i think that they broke up!
i didnt think that you were that much taller than me, i am 183 cm...
yeah they measured me at gym - 188cm :P
hmmm didnt think the magazine was that old - it was from when just after Reggie won BB!
But that would be um gross .... i mean i know shes a yoga instructor so she must be flexible but ewww i mean ewww its almost paedohpilia.
yeah thats what i was going to say would be like making love to a munchkin ..... well basically i guess you would be.
Its liek the episode of Jerry SPringer
"Who wants to marry a dwarf"
All these full grown chicks that never met this dwarf guy before were fighting over him to marry him...... some people get their jollies out of the most disturbing things.
but all of him would be mini cos it doesnt look like hes got a third leg and he wouldnt even come up to her ummm navel he would have to stand on a couple of yellow pages to get even close i think.
yeah some oif the shows are a set up but how do you explain about two years ago two Jerry Springer contestants - one murdered the other eh?
you noticed that they are alot tamer now though?? hmm??? haha
so nothing this weekend huh alex??? damn... ah well best to save some money i guess..
and they say that size doesnt matter to most women huh? ha :P
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
