  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
i lied to get out of going to a friends bday party - which i was given late notice too and he hasnt bothered to contact me in ages anyway ....... but still he came to mine and we were once really good mates (not that good he's a bit on the feminate side if u know what i mean) but do you think im a bad person? i feel really bad about it!
Originally posted by rb25
oh - sorry mate - im workin and whorin at the same time so.....
well - i live about 30mis from work and shes about 1.5hours. too far for her to drive - boo f**king hoo. she only stays one nite a week and it will stop in 2 weeks when hubby is home.
but why YOUR house?? is it work digs or something??
or did you volunteer? its a bit freaky is all!! do you get any thing out of it - apart from freaked out?
not usually - usually im pretty honest. But this week - yeah cos ive been getting in way late and leaving way early for 'brake stuff' and taking an hour for lunch ...... ive lied big time! but firstly .... no matter how late i get in - im still in before my supervisor. 2. he's constantly out to meetings so he has no idea how long i take for lunch and only he sees it and signs it so theres nobody else sees it to dob on me :P
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
