  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
time for coffee......but first a story.
my GF opened an account in her name, which we've been paying rent and food and stuff into.....anyway, the other day she was going through her statements, and for a joke, every time I put a deposit into the account I would put for sex..
so if it was for food, I would put in the transfer box "for food and sex"...and so forth.
anyway, when we applied for our home loan, we had to give them all our bank statements - including the house account and my statements!
so It looks like Ive been paying her for sex on a regular interval for the last two years. the people processing the loan must have pissed themselves.... :P
I'd just liek to say: One this momentous occasion i would like to thank all the fellow whores that made it happen .... without you i wouldnt be the whore i am today *holds up trophy* THIS IS FOR YOU :P ..... thank you *wipes away tear, gets off soapbox*
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
