  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
time for coffee......but first a story.
my GF opened an account in her name, which we've been paying rent and food and stuff into.....anyway, the other day she was going through her statements, and for a joke, every time I put a deposit into the account I would put for sex..
so if it was for food, I would put in the transfer box "for food and sex"...and so forth.
anyway, when we applied for our home loan, we had to give them all our bank statements - including the house account and my statements!
so It looks like Ive been paying her for sex on a regular interval for the last two years. the people processing the loan must have pissed themselves.... :P
I'd just liek to say: One this momentous occasion i would like to thank all the fellow whores that made it happen .... without you i wouldnt be the whore i am today *holds up trophy* THIS IS FOR YOU :P ..... thank you *wipes away tear, gets off soapbox*
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
