Paul,
Told you the car was running much better now... it's so much different! I can wheelspin all of 2nd gear now, and chirp 4th, couldnt do that before...
I'll also be looking for an exhaust place to make me a straight pipe with two flanges to completely remove the centre muffler AND cat (for racing purposes only!)
I want the ability to bolt it straight back in, it's only like 1m straight pipe...
anyone know somewhere good ?
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Kym, So why isn't Memphis at Street Weapons then?
he is. but the name "street weapons" has been around for a few years now... run by ex-fibrevision dave.
ie. he's done most of the work to Rucci's Rolla sx :)
that's where the name came from is all :(
haha aidwin ....same place as before .... my last 15mins at work on Friday my old boss from my first job here asked that i come fill vacancy here why someones on holidays - they are away for month but i said i could only do 3 weeks cos of Adelaide.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
