Paul,
Told you the car was running much better now... it's so much different! I can wheelspin all of 2nd gear now, and chirp 4th, couldnt do that before...
I'll also be looking for an exhaust place to make me a straight pipe with two flanges to completely remove the centre muffler AND cat (for racing purposes only!)
I want the ability to bolt it straight back in, it's only like 1m straight pipe...
anyone know somewhere good ?
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Kym, So why isn't Memphis at Street Weapons then?
he is. but the name "street weapons" has been around for a few years now... run by ex-fibrevision dave.
ie. he's done most of the work to Rucci's Rolla sx :)
that's where the name came from is all :(
haha aidwin ....same place as before .... my last 15mins at work on Friday my old boss from my first job here asked that i come fill vacancy here why someones on holidays - they are away for month but i said i could only do 3 weeks cos of Adelaide.
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
