Paul,
Told you the car was running much better now... it's so much different! I can wheelspin all of 2nd gear now, and chirp 4th, couldnt do that before...
I'll also be looking for an exhaust place to make me a straight pipe with two flanges to completely remove the centre muffler AND cat (for racing purposes only!)
I want the ability to bolt it straight back in, it's only like 1m straight pipe...
anyone know somewhere good ?
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Kym, So why isn't Memphis at Street Weapons then?
he is. but the name "street weapons" has been around for a few years now... run by ex-fibrevision dave.
ie. he's done most of the work to Rucci's Rolla sx :)
that's where the name came from is all :(
haha aidwin ....same place as before .... my last 15mins at work on Friday my old boss from my first job here asked that i come fill vacancy here why someones on holidays - they are away for month but i said i could only do 3 weeks cos of Adelaide.
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
