  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
thats cool Cam i understand - same thing happened with our house in Mt Lawley - owners wanted it back .... they were doing up all the scummy townhouses etc and wanted to do ours up so they could charge more :D
cam - the government needs to raise revenues somehow. the question lies in the method.
In order to provide infrastructure and public support services, the government relies upon sucking money from some areas of the public and reallocating it elsewhere.
the problem is, with road cameras they profess that they are delivering a service, when really they are raising a revenue.
speed cameras do not save lives!
yeah their reasons for the speed cameras were a little bit um generalised! but i didnt bother reading the whole 50 page document on how they can improve them :D
Paul give Simon kisses from me :D
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
