  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
ooooh im the master of dodge .... i got packaging tape holding my rear wing together ;)
LOL @ aidwin ahhh yeah when i thought his R33 was funny enough he out did himself!! poor guy - if my folks went away sooner he couldve had the ZX! mmm lotsa fun ..... but they wont let me take it anywhere cos its not insured ...... hehe they are going away this weekend and it hasnt been driven in a while .................... :) :) :(
of coarse i think someone elses car is sexier than mine!!
Sweet angel - must show me whith new bar .... me n Liz were actually wanting a pic of the three black R33 chickies cars all together ;) ..... im hoping i'll have the veilside rear on by that stage tho ..... *sigh* as you know all comes down to money!!
veilside ah... thats gonna cost man.... SAVE UPP!!! just like wat i am doing... sigh...when will i get to smell my new turbo n wastegate???? SOMEONE please tell me..... i want my TURBO!!!!
hahahaha....BAM is making a turbo right now..maybe i can grab it of him....
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
