because i am a temp and not a governemtn contractor cos they are too tight arse to make me one cos its going to cost them around $2K (thats what my temp agency will slug them to make me one)
Besides im so happy to be the other side of the building to those bitches n barsteds :) i really like who im working for now!!
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Ohhh I find it all too confusing..... maybe because I don't work in a government sector..... to me once a business has trained you to do a job and you can do it well they will not want to let you go just so the can start over again training someone else to try to do a job you can already do.... does that make sense? :)
Alex, No got back to work Biatch :)
Sub, :wavey:
Brett: Govt, Private - whatever - in my experience you get screwed up the butt by all of them - its just the govt will give you more money to do it.
no opposite Brett - completely Opposite ..... Level 2's here (which is what i am but im casual) Earn 27K+ you have flexi days off as well as your normal holidays etc .... but you are only employed for 3 - 6months at a time then they'll decide whether to keep you or not - and a lot of people here are going thru the process of reapplying for their jobs
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
    • Just like in being 14mm too small (296mm) makes it not fit, being 14mm too big (324mm) it also won't fit. You want to find the correct rotor.
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
    • I started removing the tank a while back with the intent to give it a proper clean. Got to a bolt that I couldn't undo completely due to a diff being in the way, so just said f**k it and siphoned the gluggy old fuel out and called it a day. Looking it the tank it looks less corroded than the one in the pics for that billet hanger from Frenchy's anyway. Isn't it the fuel filters job to worry about this stuff? I scraped off most the crusty shit of the hanger but will give it another go before reinstall coz maybe the fuel and return pipes are also full of gunk
