  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
haha sub - twins!! mines grey too :D .... i just say its chamelon paint ..... grey one week ....black the next :)
yeah junk food is only nice to clear up hangover :)
Sounds like it'll look sweet Kym :D
i dont know - dont know whether i can be phucked with my car anymore its a slow POS that costs me nothing but money .... jsut for the boring stuff - so im never going to have enough for any good stuff ........................... i just give up :D
