  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hahah yeh niz i do, but hes nothing like me. Skinnier, but hes the biggest stoner / dero around. He's starting to grow up a bit tho! lost his licence for doing burnouts in his 5ltr statesmen OUTSIDE a cop shop. So yeh hes not much of a catch! I have a mate who would be tho. Only problem is he's gay :D
Yeh shes just emmotional and insecure. I
