  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
same with the FconV Pro paul
FconV Pro = 2860
MAP sensor = 750
Temp sensor = 400
harness/loom = 500
and so on and so forth......
i can actually get these complete packages from japan for about 1000. i should get a few and sell em to BD4's in sydney...
i want playboy bunny stickers in red on my car but cant find them :) seen them on tonnes of cars - seen them in red on a lancer.
Im never going to get my SAU ones so i might as well put those on - just got to find where they are sold.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
