  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
:( thats no good man. Well, I lost my license testing my new EVC out :P they didnt take it then and there, but i lost all my points. I got away with it coz my last fine was in NSW and I havent paid the fine yet, so the points havent shown up. And with any luck, I'll get 6 points back in 2 weeks, so I might be ok.....
sorry working - weekend was good - beautiful weather ..... ive got a very full on next couple of weeks tho .... im starting to get nervous ... excited but nervous :)
Went to drift day as previously said :) ummm cleaned ZX and R33 ..... begged dad to keep ZX (i have plans for that car ;) ) ummm was suppose to do job application but i ran outta time and i had a mental block this morning - so its still not done :( ummmm dont think im going to be outta work when i come back anyway. I think DoIR plan to remploy me.
mum came back from melbourne and bought me some really nice clothes :P good to have her back tho even if sometimes she can be a bitch.
good weather here too. had an ok weekend i suppose. went to brisbane on friday nite to pick up EBC. Saturday to the dyno day and install EBC that arvo and tested it and tuned that nite. thats about it - more testing on sunday and got booked for speeding :P haha
cops are everywhere lately :( and this plan to consficate cars ..... isnt taking whats not yours stealing ..... or was i just misinformed about that :P you see al the letters to the editor in the newspapers - all these old farts are saying how its such a good idea and cars should be speed limited etc ..... they are speed limited to 180km.hr *evil laugh*
my contract at the department has just been extended for 6 weeks after i come back from Adelaide ..... they took me over Kirsten who i work in the same office with for this job cos i apprently know the department better ..... say what?? shes been here longer than me and is more permanent but ive moved around more i guess.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
