  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Yeh but hes already spent heaps (silver MY01 with fast n furious stickers) and hes ran a low 12.
Yeh but hes SERIOUSLY thinking about taking it to Rigoli's. For 28K you can get a low 11/ high 10 sec package with a modena dog box apparently.
Hes got quotes from Speedworks and Xspeed so hes going to get in contact with them now.
Paul, she well and truly owns me. But deep down we love it :D
Yeh but i dont wanna go to plex (or even launch my car) because i'm so paranoid about the gearbox braking (even with no mods).
I dont get any points back until late next year so i'm just going to be sensible and drive to the speedlimit. .
It will be easy.........................
Originally posted by PSI_GTSII
CaminPerth: I think I musta missed something with the Driftin thread...it was there last night?
Someone start a " i'm better than you at drifting" debate or something?
I thought as much. I did notice jash lingering a lot this morning - presumably looking for the thread..
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
