  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
of coarse i will - im not that mean.
stupid photocopying finished.
gotta rent a car bay when i get back from adelaide ..... stupid parking inspectors are driving me insane. Still that townhouse is still for rent down the road ..... wonder if they've dropped the price yet? its been advertised for about 4 months now.
theres one in West Perth in Emerald Terrace - but its my goddamn it!! haha its waaaaay overpriced tho!! so im waiting for them to drop the rent ..... then make them an offer and see if they'll drop it again.
Thing is i can almost justify renting that cos it will no longer cost me $50 in parking each week ..... and more in fines when i dont have the money on me .... it will no longer cost me $60 in fuel each week ..... lunch will be cheaper cos i can just go home for it ..... what i save almost pays for it each week.
