  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
wonder if he's coming Sat night - might give him a message .... be good to catch up aint seen him in ages!
i wish food around here was closer :) .... take me 15 mins to walk to bank n food oh well exercise is good i guess.
