  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
sup guys
aidwin, the rally car anti lags are crazy i remember shitting my pants about 3 years ago when i drove past langley park when it use to be there and i never knew what anti lag was, and there was these rally cars next to us must have been coming back from forest chase anyways as they changed gears all i heard was pa pa paa pa papap hehehe i got scared :)
adrian :(
