  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
turbs for now, crazy unjineer wants to re-do the pulley setup for the SC so hes doing that and the hair dryer is on for fun, it'll be gone by the time the next season starts tho.
hes not doing the rally, im navving for one of the c-red cars tho..
eeek passenger..
Paul yeah well when i switched from full time to part time last summer .... i got paid nearly as much as fulltime i well ..... not worth it really. Summers to good to waste and i got no responsiblity so phuck it i'll party it up this summer too.
nah im navving for jeff/lj who navved for me last year, and i managed to scare the crap out of, a couple of times
anyone want a giggle
http://cheese.zapto.org/~spkrguy//flash/badger.swf
check http://cheese.zapto.org/~spkrguy//flash/ for more stuff too
    • I refer you to this thread on PF, by someone who knows what he's doing. Paints a good picture of the humble AD09.
    • Ha, I've never pressed the X in all these years incase it removed the notification for all Admins
    • I don't know, I've never done it that way, but 1. While it is an interference engine, there is still clearance between the valves and the piston at all points in the regular timing cycle 2. There is not a lot of distance before you can't catch the top of the valve stem any more I don't know if 2 is greater or less than 1. But 3. If it doesn't work out you are f**ked, engine is coming out to disassemble so it is a big bet.
    • Semi slicks are horrible for road use, just use a high performance road tyre unless you really need the maximum grip. Noisy, unpredictable (amazing, until they are not), expensive due to very high wear and not good in cold and particular wet. And yes, it is a thing to store cars on stands instead of tyres if you know they are going to be parked up long term.....but who ever realises that a short park is going to stretch into years before it is out again!
    • I know in Australia you'll definitely get above 30c. Parked in the shade in Summer you'll be above that. 😛 But in cooler climates, you might get that warm driving on the highway for a bit, but you'd never get to full heat temp. I'll try and find some of my historical tyre temps between Aus summer and winter (be aware immin the warmer area of Aus too.)
