  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Ha , for the quality os service and some smug guy giving me the eye over the counter I am doing my own.......
I don't trust anyone any more........
TNO..........good rego
I am good at hearth!!!
And I take the first punch. Just pray I dont get back up............Industrial Relations Babay and ACCC!!!
Just to ****in prove the point...
Paul,
Rockingham is great, nothing happening where I live in the center, but the influx of scum from Kwinana and Northern Suburbs is bad in Waikiki is bad...... Better property here for the price.......50k from the city UNI TAFE, Super Cheep AUTO hahahaha :P
It's ok, better than Morley!
Where do you work?
