  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
These are the entries to a Washington Post
competition asking for a rhyme with the most romantic first line... but the least romantic second line.
Love may be beautiful, love may be bliss
But I only slept with you, because I was pissed.
I thought that I could love no other
Until, that is, I met your brother.
Roses are red, violets are blue, sugar is sweet,
and so are you.
But the roses are wilting, the violets are dead,
the sugar bowl's empty and so is your head.
Of loving beauty you float with grace
If only you could hide your face
Kind, intelligent, loving and hot;
This describes everything you are not
I want to feel your sweet embrace
But don't take that paper bag off of your face
I love your smile, your face, and your eyes
Damn, I'm good at telling lies!
My darling, my lover, my beautiful wife:
Marrying you screwed up my life
I see your face when I am dreaming.
That's why I always wake up screaming
My love, you take my breath away.
What have you stepped in to smell this way
My feelings for you no words can tell,
Except for maybe "go to hell"
What inspired this amorous rhyme?
Two parts vodka, one part lime.
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
