  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah i wanted my rear speakers installed but i thought being wet my backseat my get soggy not to mention i think i'll get more satsfaction of attempting to do it myself, finding out i cant, thoughly phucking it up, throwing a tantrum and calling friends to do it anyway :P
