  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hmm...
yes yes yes, the skills day was pretty much rained out yesterday. it was wwwwwet!
re: pas, they are continuing the race-bred theme. theyve got video footage of track events and the drift day - and are apparently looking to have time trials with gran Turismo on PS2 set up.
New shirts are being organised, with plastic numberplates as per the thread in the general SAUWA section......um....
SST are organising a pre PAS dyno day for SAUWA entrants...more than that I dont really know.
I think I may be along for the SPL input, but I'm really bummed with how my car looks at the moment, and the stereo is butt-ugly, it just sounds loud.....
I'm not keen in putting my car in for the SPL thingo when mine looks as basic as it does.. I have no special fibrglass moulding or latest amp/sub combos.. or in car tv... or neons - though I'm quite happy about that last one.. :D
but you've got a grand and a half install..
with shiny alpha thingies.
Cam, It's not how flash the thing looks, it's how loud the damn thing is:D So people bring stripped out mini's with 20" subs, even yours will look good compared to that:p
Danny, I think Al managed to cover most things, I replied in the PAS thread:D
paully - what difference will it make if we do/don't enter the SPL at PAS?
i.e., will the broader SAUWA community benefit greatly from our participation and in what way? Im happy(ish) to be involved, but I'm wary of the shopping-list history that PAS has had in the past and although I woundnt mind knowing what my car makes spl wise, I'd rather not be seen to be talking up what is really a pretty basic amp and sub combo..
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
