  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hmm...
yes yes yes, the skills day was pretty much rained out yesterday. it was wwwwwet!
re: pas, they are continuing the race-bred theme. theyve got video footage of track events and the drift day - and are apparently looking to have time trials with gran Turismo on PS2 set up.
New shirts are being organised, with plastic numberplates as per the thread in the general SAUWA section......um....
SST are organising a pre PAS dyno day for SAUWA entrants...more than that I dont really know.
I think I may be along for the SPL input, but I'm really bummed with how my car looks at the moment, and the stereo is butt-ugly, it just sounds loud.....
I'm not keen in putting my car in for the SPL thingo when mine looks as basic as it does.. I have no special fibrglass moulding or latest amp/sub combos.. or in car tv... or neons - though I'm quite happy about that last one.. :D
but you've got a grand and a half install..
with shiny alpha thingies.
Cam, It's not how flash the thing looks, it's how loud the damn thing is:D So people bring stripped out mini's with 20" subs, even yours will look good compared to that:p
Danny, I think Al managed to cover most things, I replied in the PAS thread:D
paully - what difference will it make if we do/don't enter the SPL at PAS?
i.e., will the broader SAUWA community benefit greatly from our participation and in what way? Im happy(ish) to be involved, but I'm wary of the shopping-list history that PAS has had in the past and although I woundnt mind knowing what my car makes spl wise, I'd rather not be seen to be talking up what is really a pretty basic amp and sub combo..
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
