  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Seems Cam is getting excited about Olivia's arrival, hope things work out well:D
I hope Cam understands that girlies are not like an engines.....
If they start to whin and make noise, you cant just get the spanner out to fix the problem. Even when you think you have fixed the problem, you will still hear the whinning......... :rolleyes:
MAYBE IM JUST JADED
:headshot:
sorry i was in deep shock ...... it was funny cos i remember you asking me where i was and i hadnt a clue ...... then dad asked me the same question and i ansewered something completely different ..... i just left my car in the middle of the road in this side street (yeah smart i know) and i was just pacing around it in tears i didnt know what to do
I was turning ..... car ran red light n hit me..... thats the simple version .... complicated version needs diagrams.
Originally posted by Nizmo
i just want to crawl under a rock somewhere and die ..... or vomit ..... i havent decided which yet.
Niz,
Hope you are ok, was Black Beauty the car you were in??
Big hug from me to you:grouphug:
What was the major damage??
nup - i reversed and went up side street to clear the intersection .... and waited but he never came ..... its ok i got the barsteds rego and my dads mate Pasquali who is also doing the repairs (owns a big panel beating shop in bayswater) says hes got a good solicitor and we are going to find this arsehole and sue him ........ hmmmm no need to go in all guns blazing but still he does need to be made to pay for the damage.
    • With ordering the belt, you're doing water pump and the idler and tensioner at the same time too yes?
    • This is just a dumb way of keeping the wastegate closed to make more boost. Undo it and either follow the factory setup or redo it properly. Manual boost controllers just use a spring preload to determine when to close in response to boost pressure so it no longer vents to atmosphere.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
