  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
i have the biggest splitting headache ..... just downed a couple of panadol in the hope it'll go before interview .... which i slooming rather quickly. I think i'll let the boss know what happened today in the hope he'll understand why im not so bubbly ..... cos for this position you have to deal with customers a bit and today i just look like death warmed up.
well just come back from mhy interview but on the way there the neighbours cat decided to run out in front of me and if it wasnt for some good brakes that had already been well used today and a big mo-fo horn it wouldve been roadkill. Theb a few kms up the road a 4wd decides to cut the corner and almost finish up whats left of my front end.
WHAT IS IT WITH ME TODAY??
its like im cursed ...... everything i touch turns to disaster.
And i love the job although they are really concerned with my age and how im going to handle "the boys" :P ...... and to tell you the truth as much as i would like the job im too physically and mentall ystuffed today to begin on the many reasons why they should employ me ..... im basically of the attitude "Are you going to give me the phucking job or not" today!
    • I see what you mean on that last paragraph and makes sense. I am leaning towards because I made the repair/filler area large that I didn't use a long enough block. Will minimise the area and let you's know how I go. This is random but I noticed when I put epoxy primer it felt flat but that's just temporary.
    • Tried to repair with filler only. The block is a foam block but quite hard and I put a velcro on it for sandpaper, the hook and loop system. It's not one of those super soft ones that just follow the panel. Similar to a dura block.
    • You need one of those automated sprays that puffs a nice small every 15 minutes in their room. Except swap the nice smell for chloroform...
    • Don't step down power supply size, maintain it the whole way. It's how I'd do it. OR, Id have one feed, with one joint that splits out to six smaller gauge wires that go to each coil. I wouldn't add joins like stepping from 12 to 16, at the first two coils, as if you try to continue that fashion, each joint will introduce a voltage drop. In theory, earths should be the same size as power feeds, however in this case the main power needs to be bigger due to the average size current. So the next question is, how much current do these coils actually need?
    • I think Murray is onto it. It's sounding like either it's a soft block, not long enough block, OR if you're chasing waves, you're going in the direction of the waves, instead of across them. Rotate your sanding pattern by 45 degrees is something to try. You said you're going in an X, so now instead, from the same perspective, do a "t" instead.   If you're not able to have the block sit on top of two high points, and not touch the low point between them, you'll never get it flat.
