  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Danny, Do you need extra time at SST other than the dyno day we have organised for the 5th?
Yeap, Have to setup puter to turbo setup that is in car at the moment. Bigboy is not sitting in its place at the moment (long story), Still should still hit 300rwhp but it will need some fine adjustment and a good tuner.
CYA there 2nite.
Morning Aidwin & Brett ...... dropped car over at panel beatrers this morning ..... it hit me this morning i wouldnt see her for two weeks ..... broke my heart.
Now im driving round in this oil chewing .... no radio .... power steering (doesnt feel like it) .... old bunky ford laser.
I dont care if the ZX hasnt got any insurance i drove this POS once and i absolutely hate it!!
Paul i dont have the money for a busfare at the moment let alone a cover note on the car. But it has to be reinsured when it goes ot the caryard anyway so i may try n talk my mum into covering it earlier.
